krza 3
on the Single Switch 2 there are explcit L and N pins. Usually you connect them as depicted in the manual. But what happens if you swap the cables? This is shown in the attached image.
The switch between S1 an L might not work anymore. Don´t know. Would not hurt though, especially if the device is intended to be installed in a socket.
For the consumer it would not play a role. The only difference is that no longer L is switched but N (which might or might not be critical).
But what about the device? I see 3 options: 1) It still works normally, 2) It does not work anymore, 3) It´s destroyed. Don´t want to try it out to be honest
Background: I would like to use it in a kind of mobile setup, so not within a stationary socket or switch but in a box which is plugged into a socket as any other 230 V device. And that´s the point: I can plug it either way, at least in Germany.
Edited by krzabackground added
6 answers to this question
