Smart Implant as temperature sensor: How to get the measured values exported?
krza
I don´t have a Smart Implant yet but planned to buy one and to connect 6 temperature sensors to it. However, this would make sense only if I can get the measured values exported to CSV or something. Is that possible?
I got a Single Switch 2 running today as well as a Motions sensor. Latter just shows the current temperature value but no way to get a kind of history at all. And the switch ... it shows the measured energy values but also no obvious way to get the actual values!
Thanks for any hints ;)
5 answers to this question
I don’t know what homecenter you run. Tip: fill in your profile, so you can get better answers to your questions.
If you run a HC3 you can push all values to InfluxDB and do all kind of graphs in Grafana or export it to something else.
    Good hint, thank you. I have added it in the free text. My Yubii is not listed in the dropdown list, so I had "selected "Other" there. Maybe someone should add it there.
    Sorry for the late answer, by the way. For some reason I did not get notifications anymore, the according settings had changed without my intervention as it seems. I have reset it to Email now.
    Ah, the Yubii Home is not on the list.
    the Yubii Home compares the best with the Homer Center 3 Lite. So maybe just enter the Home Center 3 Lite in your profile (and make a service request to Fibaro to add the Yubii Home to the list).
    Done. Was added already :)
