I don't know if that's coused by latest beta (5.141.59 (beta) but I'm getting quite frequent HC3 restarts probably because of RAM not being released, currently after night I have 91% and expect imminent self-reboot.
Edited by naboo
    yep, made a little research and that's a long existing problem, not only with this beta
    e.g.
    seems like Fibaro has a very major bug which they don't know how to fix or simply don't want to :((
    Edited by naboo
    ...and it's still the "Used space" that are of interest. good software should put buffer and cache to good use - why pay for memory that's not put to work?
    buffer and cache are released by the system when memory are requested for apps ("Used space")
    There is no bug here, you should look at "Used space", not allocated (including cache and buffer).
    If you got frequent restarts it is not related with RAM memory not being released, we need to verify this on your system - please create a ticket on support and we will check it out :)
    This wat i heard
    I check and RAM is fine on your hub.
    It seems like BUI shows incorrect data.
    But it's not fine
    ser my hub for a month open but no reaction yet.
    ticket created (#266356)
