Create a virtual device (button) to start a report
I want to make a virtual device (start button) to start a lua program which generates a report.
In the knowledge base I found this:
But this is all HC2 and not HC3. I cannot reproduce these steps in HC3.
So my questions are:
- How can I create a virtual device in HC3? Which steps should I follow? Any tutorial or manual available?
- When I open a Quickapp I get a edit window with on the lefthandside some options (Device, label, drag and drop). Where can a tutorial to use these options in my Quickapp?
On the HC3 we call it QuickApps, you have found the edit window. There is a manual for creating QuickApps:
You can start there. There is a small example for a slider (button) in that manual.
To catch a "normal" button, the code (next to the onInit()) could be something like:
But I would recommend to try to read through the manual first, to get a bit acquainted with QuickApps.
    Thanks.
    I could not figure out how the left panel works. On youtube I found an example. With your answer It is all now pretty obvious.
