Double Smart Module going to "dead" status in ZW 3.0 engine
I do understand, that Z-Wave 3.0 engine in beta stage and not recommended for constant usage, but it works good for me for last year.
I have only 1 problem though - several  Double Smart Module units going to DEAD status from time to time.
And it's very annoying, because there are all modules powered with UPS and 24/7/365 with energy, so, there is no power outage reasons.
after manual wakeup they work fine for 3week - 2 months and then again go to DEAD.
I can write simple module to wake up only those devices but in this case it clearly waste of CPU power and Z-Wave network load.
Is there anyone facing with same problem ?
@m.roszak - maybe you know about this problem and have some solution ?
Thank you in advance
Hello!
Do you need to click on modules directly by phisical switch to wake them up or just waking up on the interface works?
Did you pull the logs after marking device as dead in the hub?
Michał
     this one!
        I will pull the logs after next "dead" event happened and send to you via PM
    Thanks !
