Battery level of Door/Window sensor is 0%
This week I bought 4 new door/window sensors of Fibaro. I included and installed 2 of them.
Immediately after inclusion the battery level of both devices is 0% and stays that 0%
I used the batteries out of the box. I changed a battery but all stays the same.
I get notifications that the battery level is too low. But the device works fine.
What can I do to solve this problem? Is using a real 3v battery a solution? Do I need to contact Fibaro support to get an solution?
Used hard- and software:
System: HC3
Software version: 5.141.59 (beta)
@PeterBThings you can try:
-Soft reconfiguration. Don't forget to wake up the sensor in order to complete soft reconfiguration.
-Include the door sensor with security enabeld or without security when connecting to the hc3.
Edited by Fabir
Hi Peter, maybe the batteries were already empty on arrival?
    I excluded and included without s2 the security mode and changed batteries. That all did the trick.
    Strange that I bought new devices with low battery power. Anyway it works.
