Roller Shutter 3 Update
Hello everyone,
I am using the Homey Pro (early 2023) and looking forward to implement the RS3 for my venetian blinds. I already did the first test with a RS3 (unfortunately with older firmware --> 5.0) but could not calibrate it propperly.
The blinds just moved 2sec up and 2sec down, thats it.
I could read, that this may be still a problem based on the firmware and the new 5.01 firmware should work.
It is possible to update the firmware via my Homey Pro?
Thank you!
2 hours ago, Nobody_47 said:
Hello everyone,
Thank you!
You can only upgrade Fibaro modules with a Fibaro controller. Firmwares are not provided and there is no external fw upgrade tool.
You can try to send the module back to the manufacturer/distributor, the local Fibaro representative with technical support. They will upgrade you.
Another way is that you can try to find someone here who is geographically close to you and will help (you have to exclude the module, on another installation the module will be added, upgraded, excluded and sent back).
