Good Morning,
I have installed the latest version 1.19.1.
Seems that now 2 tap are needed in order to launch a scene from the app (Instead of one).
Is the same also on your side?
regards
Gianluca
9 hours ago, Gianlu said:
Good Morning,
regards
Gianluca
It's much worse than you think.
Not only that you need to tap twice on the scene, but if you tap once on one scene and then tap on other -- the previous scene executed !!!!
What happened to Fibaro QA ?
By the way it runs OK using widget. One tap and scene runs.
Edited by cag014
On iOS, the new update (1.19.1) enters a login loop. Maybe is because biometric unlock. It does the same on iPhone and iPad, both with latest iOS update (16.5.1)
The same here. Tapping on a scene first repeats the last action, next tap executes the chosen scene. BUG!
App 1.19.1 and HC2 4.630
Please update your apps to version 1.19.3 (released yesterday). It contains a fix for above issues.
