When integrating any thermostat other than The heat controller, the graphic display is not the best.
Please make a more user friendly view of the thermostat within the application.
Thank you.
Best regards,
Gormat
@Gormat projektHello and welcome to the community.
I'm also useing non Fibaro thermostats. The steering is usually made in the climate zone, where you have much more features and a nice GUI. Look below.
Try the following:
Start a new climate zone > choose your thermostats, choose the temp sensor it should follow. And give the climate zone an name. Set the 4 time sections for each day.
In the access settings, grand the user with the Yubii App, access to this climate zone.
Check out this climate zone with Yubii.
Edited by Fabir
    Thanks for this suggestion, I know about this functionality, but in this case I am forced to adjust the schedule (with 4 time sections in one day).
    Sometimes the schedule functionality is not convenient for me especially if I use an AC unit. Reason is because I don't want my air conditioner to turn on automatically.
    Also, I don't have the possibility to turn off the air conditioner inside the Zone thermostat, so in that case I have to do the "AC turn off" scene.
    If I have several AC, then it becomes a bit confusing for the user.
    I use, for example, a Quadro air conditioner, and when I control the temperature via the Zone, in that case, setting the temperature to 22°C and 23°C does not work for me. For example I set the specified temperatures within the Yubii application, and the AC is set to 19°C. I don't know if some one else have similiar problem?
    That's why I suggested creating a layout for a thermostat that would directly control the heating or cooling device, and which would have a nicer visual.
    Thanks,
    I completely agree with Gormat...The UI of a single thermostat in FIbaro is somewhat ridiculous..Just compare it to any 20 euro wifi based thermostat from IKEA or any random brand that has some mobile app..all of them has a way more user friendly lookout..on the other hand, as Fab ir mentioned, the zone feature can be a temporary solution, and hopefully Fibaro will make some improvement on this matter.
    If you are using climate zones, this QA is nice i think :-)
