QuickApp setVariable ?
Have the next script working,
How can is save the print data to Variable ?
-self:getVariable():
-hub.setGlobalVariable
-- Import the necessary modules
local http = net.HTTPClient()
-- Function to perform network discovery
local function performNetworkDiscovery()
  local api = "/api/networkDiscovery/arp"
  local url = "http://127.0.0.1:11111" .. api
  local requestBody = "{\"body\": 0}"
  http:request(url, {
    options = {
      method = "POST",
      headers = {
        ["Content-Type"] = "application/json",
      data = requestBody
    success = function(response)
      local responseData = json.decode(response.data)
      -- Process each device
      for _, device in ipairs(responseData) do
        local ip = device.ip
        local mac = device.mac
        local vendor = device.vendor
        -- Do something with the IP, MAC, and vendor information
        -- For example, print them to the console
        print("IP: " .. ip)
        print("MAC: " .. mac)
        print("Vendor: " .. vendor)
        print("----------------------------------")
    end,
    error = function(error)
      print("Network discovery request failed with error: " .. error)
-- Main entry point of the script
function main()
  -- Perform network discovery
-- Run the script
main()
Edited by morsink
6 answers to this question
fibarp.setGlobalVariable('nameGlobal',valueOutcome)
self:getVariable("varName", "value")
hub.setGlobalVariable("varName", "value")
By the way as you are typing this a popup menu with related commands appears - just choose the command there and it will enter the command with the correct syntax
Edited by cag014
14 hours ago, SmartHomeEddy said:
(@morsink is on a HC2 but asks for a QuickApp?)
Probable forgot to update the profile😀
    Correct have a HC2 and HC3. Start to use the HC3 as new basis station. And will roll out the HC2 when the basics are correct in HC3
    Thanks all for the support. Just start to learn a little bit of code wrighting.   I get working  the next QuickApp. But
     i will try this to.
     i will try this to.
    Take a look on
    , no LUA knowledge required and during the transition you can control all HC2 devices/scenes from HC3 also. Like a slave... that's what I am doing now.
    By the way I'm considering continuing to use HC2 (controlled by AOQ on HC3) as a repeater.
