hope it can be done! :)
a,b,c=2,4,6
input='a' --can collect as 'a' 'b' 'c'
for _,v in ipairs({{a,'a',A},{b,'b',B},{c,'c',C}})do
  if input==v then v[3]=v[3]+1 end
  if v[3]>v[1]then send=true end
the part v[3]=v[3]+1 i can't get it to work
thx
a,b,c=2,4,6
A
thx
You have too many errors...
First of all v is a table, so how you compare string to table (input == v)?
You should add another for loop inside.
Try to define A,B,C also.
Just for test case, have defined A,B,C=1,2,3
copy the code below and run it.
Now it works with no error. But I don't understand what you're trying to achieve, I mean don't follow the logic.😙
Please play with the numbers you need... at least the code is error free from searching point of view.
Edited by cag014
    to fast typing at my end:)
    what i try to do is ad +1 to a global every time a specific letter is called. zo in this case if 'c' is called then C+1 C=1 if 'c' is called again then C+1 C=2 when C=5 then send etc..... and C=0
    my script is for my watermeter hour day month year when specific  stand is past i get notification  but not more then say 5 times in a hour or a day  etc....
    Here is the QA if you are interested:
    -- TOP SCRIPT --
    _f=fibaro
    jT=json.decode((_f.getGlobalVariable('HomeTable')))
    Debug=function(color,Message,text)print(string.format('<font color='..color..'>'..Message..'</font>'))end
    __TAG = 'QA_'.._f.getName(plugin.mainDeviceId)..' ID:'..plugin.mainDeviceId
    telegramQA=jT.startQA.telegram
    icon='🚰'
    high='⬆️'
    low='⬇️'
    equal='↔️'
    tableName='WaterHouseTable'
    idGlobals={tableName}
    -- Telegram --
    telegram=function()local msg=icon..' QA_'.._f.getName(plugin.mainDeviceId)..': '..Message local chat_ID='141284649'_f.call(telegramQA,'sendMessage',msg, chat_ID)end
    -- Info --
    cS=257953 -- watermeterstand
    gemPP=84 --gem water liter per person
    tPP=5 -- total pesons
    mW=gemPP*tPP
    maxH,maxD,maxM,maxY=((mW/5)*2),mW,(mW*30),(mW*365)
    sH,sD,sM,sY=false,false,false,false
    debug=false
    --jI=json.decode(_f:getGlobalValue('IpTable'))
    _ip='192.168.1.45'
    _port='82'
    bugError=0
    totalBugErrors=5
    --icon= 1009--jT.icon.waterMeter
    --self:updateProperty('deviceIcon',icon)
    -- Controle for Globals --
    if #idGlobals~=0 then
        for _,in ipairs(idGlobals)do
            if _f.getGlobalVariable(v)==nil or _f.getGlobalVariable(v)=='' then
                Message=v..' rede: [nil] global is niet aanwezig!'telegram()
                    if(_f.getGlobalVariable(v)~=nil and _f.getGlobalVariable(v)~='')then b=_f.getGlobalVariable(v)else b=nil end
                    function checkGlobalVar(var)local global=false
                        if b==nil or b=={}then b=api.get('/globalVariables')or{}else global=true end
                        for k,in ipairs(b)do if v.name==var then global=true break end end return global
                    if not checkGlobalVar(v)then
                        api.post('/globalVariables/',{name=v})
                        Message='Global making: '..v..' Has been made!'
                        Debug('orange',Message)
                        telegram()
                        _f.setGlobalVariable(v,'OFF')
    -- SetTable --
    setTable=function()
        statusTable={cS=cS,h_Stand=h_Stand,lh_Stand=lh_Stand,d_Stand=d_Stand,ld_Stand=ld_Stand,m_Stand=m_Stand,lm_Stand=lm_Stand,y_Stand=y_Stand,ly_Stand=ly_Stand}
        jstatusTable=json.encode(statusTable)
        _f.setGlobalVariable(tableName,jstatusTable)Debug('yellow','Table is filled!')
    setTableReset=function()
        statusTable={cS=cS,h_Stand=0,lh_Stand=0,d_Stand=0,ld_Stand=0,m_Stand=0,lm_Stand=0,y_Stand=0,ly_Stand=0}
    if _f.getGlobalVariable(tableName)=='OFF'then setTableReset()Message='LET OP, GEEN'..tableName telegram()end
    -- Globals --
    globals=function()send=false
        h=os.date('%M')d=os.date('%H:%M')m=os.date('%d %H:%M')y=os.date('%d %m %H:%M')datum=os.date('%d/%m/%Y %H:%M')
        WHT=_f.getGlobalVariable(tableName)
        if #WHT~=0 and WHT~='OFF'then WHT=json.decode((_f.getGlobalVariable(tableName)))
            h_Stand=WHT.h_Stand lh_Stand=WHT.lh_Stand
            d_Stand=WHT.d_Stand ld_Stand=WHT.ld_Stand
            m_Stand=WHT.m_Stand lm_Stand=WHT.lm_Stand
            y_Stand=WHT.y_Stand ly_Stand=WHT.ly_Stand
            if WHT.cS==0 then cS=cS else cS=WHT.cS end
    -- SetStand --
    function QuickApp:SET(t,P)
        if t=='Hour'then h_Stand=standT if P=='print'then lh_Stand=total Debug('green',total..'L')end
        elseif t=='Day'then d_Stand=standT if P=='print'then ld_Stand=total Debug('green',(ld_Stand/1000)..'M3')end
        elseif t=='Month'then m_Stand=standT if P=='print'then lm_Stand=total Debug('green',(lm_Stand/1000)..'M3')end
        elseif t=='Year'then y_Stand=standT if P=='print'then ly_Stand=total Debug('green',(ly_Stand/1000)..'M3')end
    -- Data get --
    function QuickApp:getDeviceInfo()globals()
        self.http:request('http://'.._ip..':'.._port ..'/watermeter/api/read',{
        options={method = 'GET'},success=function(response)result=json.decode(response.data)bugError=0 if debug then self:debug(response.data)end
        Wifi=result.wifi_rssi
        factor=result.watermeter_pulse_factor
        value=result.watermeter_value
        count=tonumber(result.watermeter_pulsecount)
        stand=tonumber(string.format('%.0f',count-cS)) if debug then print('cS = '..count..' - '..cS..' = '..stand)end
        cS=cS+stand
        c=function(color,message)val=string.format('<font color='..color..'>'..message..'</font>')return val end
        for _,in ipairs({
                {h,'Hour',h_Stand,lh_Stand,maxH,sH},
                {d,'Day',d_Stand,ld_Stand,maxD,sD},
                {m,'Month',m_Stand,lm_Stand,maxM,sM},
                {y,'Year',y_Stand,ly_Stand,maxY,sY}
                })do
            --print('t='..t[1]..' time='..t[2]..' x_Stand='..t[3]..' xl_Stand='..t[4]..' max='..t[5]..' total='..(stand+t[3]))
            if t[1]=='01'or t[1]=='00:01'or t[1]=='01 00:01'or t[1]=='01 01 00:01'then Debug('green','Reset '..t[2])
                total=stand+t[3] if stand==0 then standT=0 else standT=stand end self:SET(t[2],'print')
            else standT=stand+t[3] self:SET(t[2])
            if standT<1000 then unit='L'
                if debug then Debug('grey',string.format('%s_Stand=%.0f-%.0f=%.0f '..unit,t[2],stand,t[3],standT))end
            else unit='M3' standT=tonumber(string.format('%.1f',(standT/1000)))
                if debug then s_total=((stand-standT)/1000)Debug('cyan',string.format('%s_Stand=%.0f-%.0f=%.0f '..unit,t[2],stand,standT,s_total))end
            if t[4]<1000 then p_unit='L' last=t[4]else p_unit='M3'last=tonumber(string.format('%.1f',(t[4]/1000)))end
            new=t[2]..': '..standT..unit prev='prev_'..t[2]..': '..last..p_unit print(prev..' '..new)
            if t[4]>standT then i=low elseif t[4]<standT then i=high else i=equal end
            for _,in ipairs({{t[4],standT}})do
                --print(t[2]..' l_Stand='..v[1]..' > max='..t[5])
                if v[1]>t[5]then prev=c('red',v[1])else prev=c('lightgreen',v[1])end
                if v[2]>t[5]then new=c('red',v[2])else new=c('lightgreen',v[2])end
                info={'prev_'..t[2]..': ',prev..p_unit,' | ',t[2]..': ',new..unit..' '..i}style2(t[2]..'use')
            if standT>t[5] and not t[6]then
                if t[2]=='Hour'then sH=true send=true end
                if t[2]=='Day'then sD=true send=true end
                if t[2]=='Month'then sM=true send=true end
                if t[2]=='Year'then sY=true send=true end
            elseif t[6]then
                if t[2]=='Hour'and t[1]=='01'then sH=false end
                if t[2]=='Day'and t[1]=='00:01'then sD=false end
                if t[2]=='Month'and t[1]=='01 00:01'then sM=false end
                if t[2]=='Year'and t[1]=='01 01 00:01'then sY=false end
            if send then Message='Water use high in one-'..t[2]..'. Total of '..standT..unit..' where max='..t[5]telegram()Debug('red',Message)send=false end
        setTable()
        Debug('green','-------------------------')
        info={c('cyan','Date: ')..c('yellow',datum)}style('lastupdate')
        info={c('cyan','Wifi: '..c('yellow',Wifi)..' dBm'),c('cyan','Factor: ')..c('yellow',factor),c('cyan','Counts: ')..c('yellow',count)}style('info')
        if debug then print('<div align="right">Wifi = '..Wifi..' Factor = '..factor..' Count = '..count..' Totaal = '..count..'</div>')end
        end,
        error=function(message)self:debug('error:', message)Message='ERROR: No water (Update)'bugError=bugError+1 Debug('red',Message..' error nr:'..bugError)
        if bugError>totalBugErrors then telegram()bugError=0 end end
    function QuickApp:refresh()self:getDeviceInfo()_f.setTimeout(self.pollingTime*1000,function()self:refresh()end)end
    function QuickApp:Update()self:onInit()end
    function QuickApp:onInit()Debug('green','HC3 start script at '.. os.date())self.http=net.HTTPClient({timeout=5000})self.pollingTime=60 self:refresh()end
    This part i think can be shorter then
            elseif t[6]then
