Controlling variables within HC3 Block Mode
Is it possible to increment or decrement variables within Block Mode, or can this only be done via Lua, and thanks for help on forum policy
Regards Ron
@Joep
I tried a completely new scene, I played with it a bit and I think I solved it this way. I will see if it will work as I need.
local hitCounter = hub.getSceneVariable("hitCounter")
local lastHitTime = hub.getSceneVariable("lastHitTime")
local notified   = hub.getSceneVariable("notified")
local currentTime = os.time(os.date("!*t"))
local pumpPower = tonumber(hub.getValue(187"power"))
 hub.debug("scene692", hitCounter)
 hub.debug("Scene692", pumpPower)
 hub.debug("Scene692", notified)
 if lastHitTime == nil or currentTime - lastHitTime >= 60 then
     hitCounter = 0
     hub.setSceneVariable("hitCounter", hitCounter)
 if pumpPower >= 1000 then
     if hitCounter == 0 then
       lastHitTime = currentTime
       hub.setSceneVariable("lastHitTime", currentTime)
     hitCounter = hitCounter + 1
     if hitCounter >= 5 and notified == 0 then
        hub.alert("simplePush", {1026}, "Pump is hunting!"false"")
        notified = 1
        hub.setSceneVariable("notified", notified)
else
     notified = 0
Edited by Riki
I am deleting this text. I put the same thing twice
Edited by Riki
Good news, I hope it works, have a nice day!
Hello, I have a similar application but I stuck at setting and reading the value of the global variable. The value printed is always Nil. Why?
This is the only code in the LUA scene.
