Ring keypad 2
Does anyone have experience pairing a ring keypad 2 with an HC3. The keypad has been added to my HC3 however I have no idea how to create a lua code in HC3. The purpose of the code would be to check if a PIN has been entered on the keypad and if it is the correct PIN then a scene should start. Does anyone have an idea what Lua code I can use.
