After the firmware update I get this e-mail in every 30 minutes.
I've seen that there were similar problems in the pasts but I didn't find any solution, best practice to handle this.
Suspicious login attempts prevented
We noticed 5 failed login attempts to your HC3L-00007228 that seemed suspicious.
For your security, the following IP address: 127.0.0.1 has been locked for 30 minutes.
prevented
Do you have an Automationbridge integrated with your HomeCenter?
Maybe other integrations can cause the same issue?
