I would like create a scene with Lua language from this request
curl -X POST "http://127.0.0.1:33863/airsend/transfer" -H "accept: application/json" -H "Content-Type: application/json" -d "{\"wait\": true, \"channel\": {\"id\":\"13920\",\"source\":\"15191161\"}, \"thingnotes\":{\"notes\":[{\"method\":\"PUT\",\"type\":\"STATE\",\"value\":\"STOP\"}]}}" -H "Authorization: Bearer sp://**PASSword***@[fe80::xxxx:xxxx:fe4d:9d2d]?gw=0"
Do you have an idea how to transfrom this request to LUA Code ?
Kings regards
Julien
  • 3 weeks later...
Assuming that you've got socket.http library in your Lua environment, you can use the code below. (Also I should mention that you need to replace place holders with real values before using the code)
-- Load the http library
local http = require("socket.http")
-- Define the request parameters
local url = "http://127.0.0.1:33863/airsend/transfer"
local headers = {
    ["accept"] = "application/json",
    ["Content-Type"] = "application/json",
    ["Authorization"] = "Bearer sp://**PASSword***@[fe80::xxxx:xxxx:fe4d:9d2d]?gw=0"
local payload = [[
    "wait": true,
    "channel": {
        "id": "13920",
        "source": "15191161"
    "thingnotes": {
        "notes": [
                "method": "PUT",
                "type": "STATE",
                "value": "STOP"
-- Make the HTTP POST request
local response, status, headers, statusline = http.request{
    url = url,
    method = "POST",
    headers = headers,
    source = ltn12.source.string(payload),
    sink = ltn12.sink.file(io.stdout)
-- Print the response details
print("Response:", response)
print("Status:", status)
print("Headers:",
headers)
print("Status Line:", statusline)
On the HC3 there is no socket library, but the net.HTTPClient
