Guest chriss2
hi
I am looking for an answer to the question whether it is possible to control the setting of the fibaro thermostatic head using the MCOHome panel..
example of use:
The temperature indicated on the panel is 21 degrees.
I set the temperature on the panel to 23 degrees.
The panel communicates with the thermostatic head
The thermostatic head opens the valve and keeps it open until the panel reaches a temperature of 23 degrees.
is such operation of fibaro devices (thermostatic heads and gate) and MCO possible?
