Hello All,
I am new to Fibaro Community. I have Fibaro Home Centre 3 Lite with the below Config and I am based in Singapore.
HC3L-001
Wifi 2.4 GHz
EU868Mhz
My question is if I buy the below product online... can I use with my above HC3L Gate Way - Appreciate if anyone could advise me on this please.
Z-Wave Fibaro Double Switch 2
  • Radio protocol: Z-Wave+
  • Wireless: Z-Wave (868.42MHz)
  • Radio signal power: up to 1mW
  • Voltage: 110 - 240V AC
  • Maximum load (per channel): 6.5A (Resistive)
  • Maximum total load: 10A (Resistive)
  • Power Consumption: < 0.8W
Why I was confused is becuase my Gateway Specs are  EU 868 Mhz and this Double Switch Spec are 868.42 MHZ
Thanks in advance.
@NalanHello and welcome to the community.
The approved Z-Wave frequencys for Singapore are 920.9, 921.7 and 923.1 MHz
Look
for the country list.
You should only use Z-Wave controllers and devices approved for your country.
Also you can only connect Z-Wave devices to each other, which have the same Z-Wave frequency build inn.
16 hours ago, Nalan said:
Hello All,
HC3L-001
Wifi 2.4 GHz
EU868Mhz
Thanks in advance.
Looks like you have EU frequency hub.  So yes, double switch 868.42MHz will work for you. Actually, any Zwave device that you intend to connect to hub, must be on that frequency.
To make sure that you EU version please verify system info:
http:// [HC3L-IP] /api/settings/info
verify
Edited by cag014
    Thank you all for your Valubale Inputs and Time. Much Appreciated.
