How mesure injection power from auto-consumption
Hello
  I've recieved recentlty the PowerStream from Ecoflow, to inject energy in my house.
I would like to use wallplug to follow energy injected, but in HC3 the module return 0
I didn't test on other domotique solution, but in Jeedom process seem work correctly.
Do you know if it's an "limitation" of HC3 ? Or it's just an setup not done correctly ?
I've test with other module similar at WallPlug, same result
