No longer able to set thermostat in Holiday Mode on HCL
Guest ChristS
After the update to 1.19.3 on my Android I am no longer able to set thermostat (Heating Panels as they are called on HCL) in Holiday Mode. I used to do this via the Yubii app by selecting the respective themostat in the app, selecting the desired temperature and selecting 'Hold' then press Save. This does no longer work, when I do it the thermostat temperature does not change. When I check in the HCL web interface I see that Holiday Mode has been activated, but the temperature is set to 'none'.
@ChristSThe same issue here with HCL on 4.6.30 and Yubii Android 1.19.3.
In HC3L and Yubii Android 1.19.3, the Thermostat settings are still working as expected.
