update global variable which is set to enumValues
I have a home table which contains a list of speakers
i thank have a variable called sonosPlayer, with a enumValues of the speakers
what I am trying to do is on save of the hometable to remove all the enums which are not in my list of speakers and add the speakers which are in it.
i tired this, but it does not work, can anyone give me some help on how to get ti working?
Many thanks for any help provided.
--Update Speaker Variable with list of speakers
local gvName = "sonosPlayer"
--local gv = api.get("/globalVariables/" .. gvName)
local speakersList = "" -- Initialize an empty string to store the speakers' IP addresses
local jT = json.decode(fibaro.getGlobalVariable("jHomeTable"))
local counter = 0
-- Loop through the "jT" variable to find the list of speakers' IP addresses
for k, v in pairs(jT) do
    if k == "Speakers" then
        for k2, v2 in pairs(v) do
            counter = counter + 1
            -- k2 is the name of the speaker
            -- v2 is the IP address of the speaker
            if counter == 1 then
                speakersList = v2
            else
                speakersList = speakersList .. "," .. v2
-- Update the "sonosPlayer" global variable with the list of speakers' IP addresses
print("Speaker list "..speakersList)
api.put("/globalVariables/sonosPlayer", { value = speakersList })
--output the values of sonosPlayer Variable for debugging
local sonosPlayerVariable = api.get("/globalVariables/" .. gvName)
print(json.encode(sonosPlayerVariable))
    i have tried this too
    local counter = 0
                    speakersList = v2
                else
            name="sonosPlayer",
            value=""-- optional
            isEnum=true,
            enumValues=
                    speakersList
    • So you have a Global Variable jHomeTable and a Global Variable SonosPlayer?
    • In the jHomeTable you have a property (list) for your Sonos speakers?
    • You want to read the list in jHomeTable and match it with SonosPlayer? So replace the property (list) with SonosPlayer?
    If I understand it correctly please post an example of the SonosPlayer value and jHomeTable value (please strip everything except the SonosPlayer property, to help you I need the structure.
    Edited by Joep
