Send a PUSH message if the event repeats 3 times
Can anyone help with this task? My point is that if the electric pump is turned on at least 3 times within 1 minute, I will be notified by a PUSH message. I created it, but it's probably stupid. Its not working. I am a new programmer, thanks for your help.
conditions / trigger
    id = 187,
    isTrigger = true,
    operator = ">",
    property = "power",
    type = "device",
    value = 1000
ACTION:
local deviceID = 187
local threshold = 1100
local numChanges = 0
local startTime = 0
local pushSent = false
function sendPush(message)
  local receiverIDs = {1026}
  hub.alert("simplePush", receiverIDs, message, false"")
while true do
  local power = tonumber(fibaro:getValue(deviceID, "power"))
  local timestamp = os.time()
  if power > threshold then
   if numChanges == 0 then
    startTime = timestamp
   numChanges = numChanges + 1
   if numChanges == 3 and timestamp - startTime <= 60 and not pushSent then
    local pushMessage = "PUMP!!!"
    sendPush(pushMessage)
    pushSent = true
    numChanges = 0
    return
 fibaro:sleep(1000)
Edited by Riki
9 answers to this question
@Riki
Hello, ...ahoj :)
1) This section of the forum is led in Anglictine.
Pis here in English and certainly do drive dockas answer
To programming,...
because you are well in the road and you try to solve things alone, so I draw basic things.
- Unused diacritics in programming! You should switch into the Slovak language, Lua can not get with it.
- In programming, unused compound expressions with a gap, but always instead of a space of use, need underlines.
For example: časová pečiatka = casova_peciatka
    @Martin_N
    Thank you for warning. I have already corrected the text into English, as I originally intended. Since I automatically use google translator on the pages, the original text was messed up and I overlooked it.
    Edited by Riki
    I modified the program as follows, but it still does not work. Can someone please help?
    @Martin_N can you please see the error there?
    conditions/triggers:
      conditions = {
          id = 187,
          isTrigger = true,
          operator = ">",
          property = "power",
          type = "device",
          value = 1000
              operator = "count",
              property = "occurences",
              type = "device",
              value = 3,
              duration = 60
        operator = "all"
    ACTION:
    hub.alert('simplePush', {[1] = 1026, }, 'The pump started more than 3 times per minute!'false'')
    Edited by Riki
    @Riki
    I can't verify this now (I won't have access to HC3 for another week), I don't have experience with the count trigger. Maybe someone can advise you faster.
    Anyway, I think you need to add isTrigger=true to the second condition.
    eM
    @Martin_N
    I also added to the second condition (isTrigger = true) but it didn't help. But thank you for the quick reply. I hope someone will know the answer.
    edit: If I have only the first condition in the program (I remove the second one), then the PUSH message is immediately sent as a pump exceeding 1000W power. So the error will be somewhere in the second condition.
      conditions = {
          id = 187,
          isTrigger = true,
          operator = ">",
          property = "power",
          type = "device",
          value = 1000
              isTrigger = true,
              operator = "count",
              type = "device",
              value = 3,
              duration = 60
        operator = "all"
    Edited by Riki
    @Riki
    Ah... so it's a misunderstanding of the structure.
    You can't have a counter in the condition because you have no way to initialize it. You leave the first condition and you have to create the reader programmatically in the actions... and the result will be the desired functionality.
    Actually, it will be similar to your example from the first question in the thread...
    I'm not sure if it's possible to grant a compound function already in conditions, I've never done it in conditions.
    This looks like the same question
    right?
    @Joep Yes.  And thanks for the help.  Again, I learned something about LUA.  I know about your site, you are teaching, I will follow it and look for more answers to questions.
    This is a tried and tested functional solution to the problem :)
    local pumpPower = tonumber(hub.getValue(187"power"))
     if  pumpPower >= 500 then
         local hitCounter = hub.getSceneVariable("hitCounter")
         local lastHitTime = hub.getSceneVariable("lastHitTime")
         local notified = hub.getSceneVariable("notified")
         local currentTime = os.time(os.date("!*t"))
         local WC_preteka_voda = hub.getGlobalVariable("WC_preteka_voda")
         hub.debug("Scene698""---------------------------")
         hub.debug("Scene698""vykon čerpadla: " ..pumpPower)
     --   if pumpPower >= 500 then
         if lastHitTime == nil or currentTime - lastHitTime >= 120 then
           hitCounter = 0
           hub.setSceneVariable("hitCounter", hitCounter)
           lastHitTime = currentTime
           hub.setSceneVariable("lastHitTime", lastHitTime)
          if hitCounter == 0 then
           hub.setSceneVariable("lastHitTime", currentTime)
          hitCounter = hitCounter + 1
          hub.debug("Scene698""hodnota hitcounter: " ..hitCounter)
          hub.debug("Scene698""Notifikacia: " ..notified)
          if hitCounter >= 8 and notified == 0 then
              hub.alert("simplePush", {1026}, "LUA - POZOR! Čerpadlo často zapína! WC?"false"")
              notified = 1
              hub.setSceneVariable("notified", notified)
              WC_preteka_voda = "Áno"
              hub.setGlobalVariable("WC_preteka_voda", WC_preteka_voda)
              hitCounter = 0
           else
              notified = 0
