I am looking for some our side door sensor for window blind because currently my window blind doesn't send information about state. I want to use smart implant and reed switch but I can't find any small solution for that. Can you recommend some solution?
9 answers to this question
@Krystiann What do you mean by "Reed switch"?
Fibaro's UBS is a relatively old product, but it's fine for your application. But... Smart implant has its own case.
@Krystiann
What are your size requirements?
For example, one of the smallest is the MPS45W - Honeywell.
Different magnets require different mounting methods.
MC740 - Alarmtech, 401TF - Eaton,.. and many others.
    W dniu 12.08.2023 o 16:48, Martin_N napisał:
    MPS45W - Honeywell.
    Is fine for me. I just want to something small which works with Smart implant :)
    @Martin_Ndo you know universal binary sensor is okay for Reed switch?
    I mean door sensor
    I mean door sensor
    Quote
    I mean door sensor
    Yes... Yes,...
    UBS is suitable for detecting open doors using a magnetic contact.
    It is functionally very similar to SI. SI can also measure analog quantities at the inputs.
    I am trying to connect Satel B1 with UBS but for now is not working :)
    @Krystiann
    sorry but...
    1) the first question was about Smart Implant
    2) you are in the Smart Implant section
    3) if you connect an ordinary contact to the input, it must work. Otherwise, read the manual.
    You can also write how you have the magnetic contact connected to the UBS... I'll check and maybe help.
    @Krystiann
    Hi Krystian.
    Let's open this topic, because you are asking about parameter 20 for the Smart Implant in the fiber to the UBS.
    Check out this link.
    Can you please take a photo of the power supply, its parameters?
    eM.
