Doubt about QuickApps
Hey there,
I am investing my time here trying to make my home work properly :)
I want to create a QuickApp that can "read" a sensor from my home (e.g. door sensor, switch) and, then, go and make something else.
In general, I want to create a QuickApp that that, once I push its button, it can turn on a device/scene and, at the same time, being able to adapt than virtual button to a real sensor.
For example: imagine a fibaro switch. I would like to be able to:
- Once it its phisicallly turned on I got a notification and it turns off a light and turns on another one
- If I push the virtual button, I have the same result as above.
Any ideas?
Thanks!
6 answers to this question
Create a scene for this. You can automatically trigger the scene and also run it manual from the Yubii app.
    thanks. I know I can do this, but i am trying to play with the virtual device since I want to make an advanced implementation with Alexa.
    As you can’t use triggers in a QA (they are not made for it) I would program the QA that it works as you want with the button you create.
    Then create a scene that triggers on the wall switch and activates the function (your button handler function) in your QA.
    For example: hub.call(qaId, “ButtonPressed”, “”)
    thanks. But how do i made the “Connection” between an ID and the button created in the QA?
    The button triggers a function, if you edit the GUI select the button and look which function it starts:
    /monthly_2023_08/image.png.ccc0d3fbfbdad2830f6dbf42fad11771.png" />
    Then look in the code for the function:
    In your scene the blue arrow is the function name and the red arrow is the parameter you pass to the function (if you don't use that, use a blank string):
    The qaId in the scene code is the id of your QA.
    I short; if you press the button in a QA you start a function (see above), to "press the button" from a scene, you just start that function with the code I shown you. So you don't press the button, but start the same function.
    Edited by Joep
    better explanation
    thanks, mate. Thanks to you, I am now able to make a button made the exact same thing as one of my devices :)
    Is it any way that, once of my door sensors (or motion) is activated, it actuates with the virtual device I have just created? Thanks again.
    Edited by Vicent13
