net.HTTPClient:request, URL issue sending "Scope"
I would like to get some guidance understanding following situation.
System: Yubii Home
Software version: 5.140.17
What I want to achieve?
- get actual power from my Fronius PV inverter through http get request
- the valid url is following:
Observation:
a) send url via browser --> all ok, returns expected data (json)
b) using ZeroBrane Studio with HC3 simulator --> all ok, returns expected data (json)
c) placing identical code (as in b) to my Yubii Home scene --> returns error message, ".. Reason" : "CGI-Args: Invalid parameter '' for attribute 'Scope' (use 'System' or 'Device') .. "
What I have tested?
a) using a modified url with small letter "scope" instead of "Scope" via browser --> returns error message as per observation c
b) using a modified url with small letter "scope" instead of "Scope" in ZeroBrane Studio with HC3 simulator --> returns error message as per observation c
What I would expect?
- json data return example
And finally the code used in my scene:
Would appreciate any help to understand what I need to change in my scene Lua code.
    Learning the hard way...😂
    found finally this
    ..need to encode the url in scene due to different implementation vs QuickApp.
    Using in scene following resolved the issue:
    Thanks to @tinman
    Edited by bgs
