Upgrade without HC?
Guest dafgfdgdfg
So is it still a requirement to purchase the HC, do upgrade, and then return it back to the seller in order to upgrade three heat controllers? I mean I have done this a couple of times already, but it's quite annoying process.
I am only considering to go through this stupid process because I've read the 4.9 FW fixes issues with battery drain, which is a massive pain.
@dafgfdgdfgHello and welcome to the community.
AFIK there's no possibility to update a Fibro device without a homecenter. Maybe consider to buy the small Fibaro homecenter light HC3L, in order to do that.
Guest dafgfdgdfg
    @Fabir Sure I will. Buy and return. As always. It is just annoying to disconnect the heads from my system, connect it to the HC, update it, remove it from the HC, connect back to my system and return the HC back to the seller.
    Do I regret buying the Fibaro heads 4.5 years ago? Yes I do.
