gcosta56 0
Hello Fibaro Community,
I'm working on a project involving the Fibaro FGBS-222 module and an analog anemometer that operates on a 12V supply and delivers a 0-5V signal.
I'm facing an issue that I hope someone here can help me with.
Setup:
Problem:
When the anemometer is not turning, it delivers a voltage of 8 mV.
However, when I connect the blue wire to the IN1 pin on the Fibaro module, the voltage reading jumps to around 0.14 V.
This discrepancy is causing issues in my system.
I've tried various configurations and settings, including adjusting parameter 20 on the Fibaro module, but I haven't been able to resolve the issue.
Questions:
Any insights, suggestions, or guidance would be greatly appreciated. I'm happy to provide additional details if needed.
Thank you in advance for your help!
Guillaume
