Slat rotation control not working for NICE blinds
I cannot get the slat rotation control to work with my NICE blinds. It works fine via the NICE P1 remote and the slat rotation control is available in the Yubii web interface (see attached picture). I've also tried to set a favourite position but that also doesn't work. Any pointers would be appreciated!
The commands for up, down and stop are working fine.
I'm on SW version 5.140.17.
Kind regards,
Kim
Edited by Mr H
6 answers to this question
@Mr HHello and welcome to the community.
Did you set the category and the rolle? Look below.
Run the calibration again.
    Yes, it is set exactly like your screenshot. I tried to change the role to blinds with no positioning but then the UI changes and the slat rotation is not visible anymore.
    @Mr HI don't have a Yubii homecenter to test it out. I've got hc3 and hc3l. In my case the blind slat rotation is working.
    Do you use Fibaro Roller Shutter 3 FGR-223?
    Which Zwave Engine is installed on your hc, 2 or 3?
    Things you can try:
    -Recalibration
    -Restart hc
    -soft reconfigruration of the device
    -exclude / include the device again with or without security
    I use the native NICE integration in the Yubii Home (this was the main selling point for me as I only have NICE blinds throughout the house), so I think the problem is related to the NICE integration unfortunately.
    @Mr HOK, in this case open a support ticket with fibaro.
    @Mr HCould you solve the issue with the nice blinds on Yubii home?
