motion scene delay 30min
Wonto
With my HC3 I run into a challenge with regard to scripts. I wrote a script that switches on the lighting on the entire floor when there is movement.
Now I also have a script that dims the lighting to 32% by using of a push button.
Now it comes: if movement is detected again, the lighting will return to 100%, this is not the intention.
It would be nice if there is the possibility that after pressing the button the scene for lighting 32% the scene for movement does not work for 30 minutes.
scene to put the lights on by movement:
trigger:
  conditions = { {
      id = 149,
      isTrigger = true,
      operator = "==",
      property = "value",
      type = "device",
      value = true
      id = 148,
      isTrigger = true,
      operator = "==",
      property = "value",
      type = "device",
      value = true
  operator = "any"
action:
hub.call({[1] = 65, [2] = 56, [3] = 34, }, 'turnOn')
hub.call(90, 'turnOn')
scene to put the lights 32%:
trigger:
  conditions = { {
      id = 83,
      isTrigger = true,
      operator = "==",
      property = "centralSceneEvent",
      type = "device",
      value = {
        keyAttribute = "Pressed",
        keyId = 1
  operator = "all"
action:
hub.call(34, 'setValue', 32)
hub.call(419, 'turnOn')
