Peppe 0
I have the following need:
Disable Fibaro roller shutter device while alarm sensor in breached using an HC2 device.
In the actual case, while the window is open I need to disable the roller shutter device that move the curtain.
Through LUA I'm able to recognize the sensor breach, but I'm not able to disable the wanted device.
I'm actually also struggling in just retrive the enable state.
I'm able to get roller shutter name, Id and other stuff through undocumented commands:
fibaro:getName(590)
fibaro:getDevicesId(590)
But I'm not able to find any command to get the enable state and nothing to change its value using lua commands.
The only way I found to inspect the enable value is through the filter capability but it seems to me far from an actual solution.
Someone can help on this?
Thank you for your support!
12 answers to this question
