HC3 Lite - alarm panel
What settings should I make when there is a general alarm, certain bulbs should flash. Thank you
7 answers to this question
@wrongeuGo to: settings > alarm > Create an alarm zone > select the sensors that should be used in this alarm zone like motion sensors, door sensors etc.
Go to Alarm scenes > Create an alarm scene > choose the previously created alarm zone as the trigger for the scene > in the section do the following > add the bulbs you want to flash in case of an alarm.
Activate the alarm zone and test it out.
    Hi
    I did that, but when setting the bulbs, I have no way to set them to flash/blink.
    @wrongeuCan you tell which bulbs you have? If they are not themselves zwave devices with flashing capability, you would ned a switch modul like the FGS-223
    . You can set the output into flashing mode and connect the bulbs to it.
    I have two dimmer 2 ... I set the parameter in the dimmer to react to the general alarm, but once the alarm is triggered, they don't light up at all.... in the scene, if I add them, they light up (but don't blink)... I'm probably wrong somewhere, but I do not know where....
    @wrongeuCan you show the alarm scene? Fibaro dimmer 2 don't have a blinker/flash mode for the output. Therefore I recommend a switch modul like the FGS-223 above, it has got 2 output channels.
    @Fabirso that was the problem....thanks a lot for your help
    @wrongeuYou're welcome.
