Walli with Delta Dore Tymoov X3D motors (sequential when used in wired mode)
Hi there,
I purchased several Walli Roller Shutter commands for my roller shutters at home. I love the design and the features, really amazing product.
It works well with 7 of my roller shutter which are using wired motors with 3 wires (blue = neutral, brown = going down, black = going up). All good.
Sadly, 4 of my roller shutter are using the radio enabled version of the same motor (Delta Dore Tymoov X3D). Those have the same wires but the wiring is totally different: blue = neutral, brown = phase, black = push switch. In this configuration, I can only use the motor in sequential mode (going down... stop... going up... stop... going down, etc.). I did not manage to configure the Walli unit to it accept this kind of mode yet. In Home Assistant, it still shows up / stop / down but the commands get all messed up as the roller shutter does not behave as it should. The positioning is also non existent with this configuration.
Instructions (in French sorry, I did not manage to find them in English) :
I think Delta Dore has a great job at making sure you stick to their ecosystem as their motors have to be used with their ****** Cloud based solution...
If you have any great ideas so I can keep the Walli in my living room, I would love to hear about it ;-)
Cheers,
D.
I translated the picture with a website
