HCL recovery procedure required after every power outage
Hello all,
I have a HCL from June 2017.
Since a year I have to run a system recovery every time when there is a power outage.
Otherwise I am not able to control my lights via the mobile App or via laptop.
I run the recovery procedure by switching off power and switch back on with + pushed.
Then via IP address I am getting to the recovery page and continue to install latest backup.
How can I solve this issue??
best regards
Daniel
Goes-Netherlands
@Daan_37Hello and welcome to the community.
Are you on the latetesd Firmware 4.630?
i don't know many times a year, this will happen to your HCL.
If this happens multiple times a year, I recommend to start from scratch with a new homecenter like HC3, HC3L or Yubi Home.
Things you can
Could this be a backup battery issue?
