Howto create alternating mode with rgbw controller?
PieterQu
Hi!
I am trying to get a Fibaro RGBW in alternating mode with a toggle switch. But I can't figure it out. Following the manual (switching the 'earth' on the 4 inputs) I cannot get it to work the way I want.
Bottom line…: if I turn off the LED with the switch, I can no longer turn the LED on with the homey pro 2019.
Does anyone have a tip?
@PieterQu
Hello.
Use the settings of section 20-23 and set the Toggle switch mode (value 3).
This setting applies to scene control. You will then have to create a scene in your controller and then control this scene with a toggle switch.
If you want rgbw2 directly control (without scene), you have to replace your wall controller with a button.
eM.
