Trying to get the output of Smart Implant to Normally Closed when connected to HC3
Ronald H
Hi all
Have been using the Smart Implant with good success, but for the first time I want to set Output 1 to Normally Closed, so I set Parameter 154 to 1
However this o/p remains Normally Open. How do I force the Normally Closed option. Powering off then on again had no effect
9 answers to this question
  • Thankyou Neo for your response, but am I missing something? It is the Output I want made to be Normally Closed, not the input, which is set to Monostable. Please correct me if I have misunderstood your response
    Ron
    @Ronald HI've checked with one of my Smart Implant, OUT1 and OUT2 react as expected. When I set parameter 154 to 1 = OUT1 = is normaly closed. And OUT2 does the same with parameter 155 to 1.
    Things you can try:
    -disconnect the power supply to the SI and connect again.
    -restart hc
    -soft reconfiguration of the smart implant
    -exclude / include the smart implant again. With or without security.
    Ron
    Yeah my bad..i didn't realize you are talking about output
  • Thanks All for trying to help - BUT STILL NO GO
    1. Have set Param 154 to 1 to set O/P 1 Normally Closed - no go - stays Normally Open
    2. Have set Param 155 to 1 to set O/P 2 Normally closed - no go - stays Normally Open
    3. The operate time on both Outputs = 1 sec
    4. The outputs are switching an external relay via the same +12v that operates the Smart Implant
    5. I assume that both Outputs are totally isolated dry contacts
    6. Can a SI Output remain Normally Closed for many hours without a positive operation
    7 Have tried powering off the SI and restarting the HC3
    8. All parameter changes are manually taking place and saved through the HC3 Parameter section
    What am I overlooking
    Ron
    Hi @Ronald H ,
    before changing parameters 154 and 155 for output, have you checked how parameters 20 and 21 for inputs are setup and what you have connected there?
    @Ronald H
    I have already described the "strange behavior" of SI in the past. In a previous post I posted a link to the thread where I addressed this. Look at. Please give me feedback if this leads to anything.
  • Hi to all who helped
    I'm afraid in my ignorance and hours of trying using the above suggestions, I still couldn't get O/P 1 to be Normally Closed while it's I/P 1 remained isolated and set to Monostable.
    So I did a workaround keeping O/P 1 to be Normally Open. At least the system works in this mode. But THANKYOU
    Regards Ron
