Gabor1 3
Hi all,
I have a question, need help from all the pros.
The situation is simple. Given a fibaro heat controller FGT-001 without external temperature sensor. I do understand, open window detection monitoring the change of the temperature, and if within 15 minutes, it is falling rapidly, it took it as a window open, and close the radiator valve. My questions are:
- how long it stays closed
-what is the difference with rapid open window detection
- can i somehow read the parameter if window detection is on, then an alarm would be set after like 10 minutes?
-if yes, how?
we speaking about a large number of radiators, mostly under or next to a window, and I would like to save on window sensors.
Thank you in advance
4 answers to this question
