Can't set values above 30 degrees on climate zones
In the climate panel of the HC3 it's now fixed that you can set temperature above 30 degrees Celsius but in the APP (iPhone) it is still not possible.
I use a climate zone for my heating system this is less work than creating an own quick app and works perfectly. I only have to set the temperature up to 60 degrees Celsius.
Sometimes I want to overrule the schedule of this zone it depends on holiday and weather conditions.
In the iPhone app it is not possible to set the temperature higher then 30 degrees. Not in the app and not in the widget.
Why limit this temperature to 30, looks like easy fix to increase the maximum temperature setting here.
