Angelus 0
Hi, i'm trying to create a single Light Check scene that is triggered by change in LUX sensors from around the house, and after a pause of x minutes it runs checks in the room corresponding to the trigger to adjust light brightness.
However, when i try to use hub.setTimeout, the instances don't seem to 'stack' ie. when LUX A is triggered and paused, if LUX B is triggered, the scene only completes LUX B's checks and forgets about LUX A -
as you can see, Study LUX shld have triggered a check but only Living LUX was captured.
I tried inserting setTimeout into the if statements as well -
this doesn't work either - despite multiple triggers only the last triggered scene is running
Any gurus able to advise what i'm doing wrong?
