Braetex Electrical 0
Hi, has any one had issues with using Hager (WBME5A)electronic switches and the Fibaro Dimmer 2? I’m finding that the dimmer only works as a relay on and off and not able to dimm the Downlights even after changing parameters in the Homey. The Downlights are only 13 watts each and if I test one on its own it will dimm but not all 6.
