HC2 - Problems with communication some fibaro Plugs
Guest pblacky
I have 2 FibaroPlugs that keep dropping out of communication because I trigger them often!
I bought a small script where I manage the IDs of the plugs via a global variable.
This is necessary because the functionality of the plugs keeps changing for me!
I've already tried 2-3 times with several plugs, it works 5-10 times, then the plug in the HC2 no longer works!!
It cannot be activated either via the script or in the interface. However, switching works on the plug itself!
Here is the script I use:
I'm at a loss because it's always reproducible despite deleting and relearning it several times :frowning:
Does anyone have a hint??
