all fibaro motion sensors lost contact the same time
I have 3 sensors and all 3 of them are no longer connected at the same time. Sensors respond to movement, but the connection is lost for all 3. Re-adding doesn't work anymore either.
Anyone else have this problem?
Half of my AEOTEC motion  sensors are not able to connect. According Fibaro will be solved?? in next update.
Wierd only half is having problem the other 4 are working.
soft re-add
Facory reset
add as new
add in safe
change from USB power into battery powered
All not succesfull
    I now notice that I can no longer add other devices. Not really reliable anymore if devices suddenly lose the connection. Especially with motion sensors and door contacts.
    What firmware are you running?
    5.141?
    Edited by ppeterr
    I run 5.141.59 as result of an error unable to back up in 5.140
    Personally I don't run beta versions.
    If you can't add devices sometimes it will help to restart HCx
    5.141?
    fw 540.17 is now in use
    I think you mean 5.140.17, if you ask me that is one of the most stable firmware's. (for me)
    But also, and i am not sure at all. Was the .17 not pulled back because of some other problems?
    Edited by ppeterr
    Already tried restarting, also tried the latest beta version but the problem still persists there.
    yes, that's what I mean indeed. 5.140.17.  I haven't had any problems with it, but now suddenly all sensors are no longer connected. Adding also no longer finds a device.
    Already restarted and tried the latest beta version but without success.
