Hi
The dropdown control is a long long awaited update, but some single description would be appreciated.
How to dynamically populate the dropdown options?
What is the toggle callback syntax?
etc
We are working on updating manuals on manuals.fibaro.com :)
    Meanwhile can you please give me some hint, how to programatically populate options?
    I have tried this, but it doesn't work
    We will prepare some examples :)
    @Neo Andersson you can try my demo qa :)
    • Thanks 2
    " to "
    Temat został przeniesiony z "
    " do "
    I try to install the update, process started looks like the update is installed but after the reboot Home Center still says this update is available and the installed version is the previous beta version.
    Tryd severall times but no solution.
    self:updateView("modeSelector""selectedItem", itemID) does not work for me. It resets the combo and awlays cancels current selection :-(
    I checked provided demo with 5.142.83 (beta)
    So the demo does not allow to sellect any item - selection is cancled from code immediatelly.
    Change Selection button (used after Change Option) also does not seletct "turbo" item
    Update of combo content by Change Option button works fine.
    BUT !!! When I use Selection button (after Change Option) - no "turbo" selected, but when I close QA view and display it again - "turbo is selected". So it looks as UI refresh issue. I checked in web UI and via Yubii APP (1.20) - it is same behavior
    Would be nice to be able to select an item also from scenes (of course when it is dynamic, it is not obvious how to handle it). Now it shows stange option in scenes, which converted to LUA calls this:
    hub.callUI(4025'onToggled''modeSelector')
    Edited by Albert
    It is also bit pity that to toggle state of new switch-type button, we have to set true/false value as a string, ex:
    self:updateView("btnSwitch""value""true"
    i would expect
    self:updateView("btnSwitch""value"true
    (it does nothink now)
    In case of visible flag it is fine, we call
    self:updateView("btnSwitch""visible"false
    and call for
    self:updateView("btnSwitch""visible", "false"
    does nothink.
    So with switch-button value, it looks as a bug.
    Please fix before we will start to use it in our QuickApps.
    Edited by Albert
    i would expect
    and call for
    does nothink.
    It has always been the same issue for slider values
    self:updateView("slider""value", "20") works but (the more "logical") self:updateView("slider""value", 20) doesn't.
    Seems like it always wan't the value view property to be a string. The visible view property they could make a boolean arg...
    Same for me. Impossible to install new beta.
    Also the same for me.
    Have you read the pinned topic?
    • 1 month later...
    On 10/20/2023 at 9:14 PM, Albert said:
    Yeah, full of bugs, same as the Switch control.
