Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.
Main features:
1. Added Auto and Manual Mode support for Elero devices.
    From now on, for devices that support mode switching, you can exclude specific devices from automation (such as scenes or profiles) by changing a single option in the sidebar.
2. Added Z-Wave Network Diagnostics tab.
    Now, for both versions of the Z-Wave engine, the system allows for the analysis of traffic and network issues for diagnostic purposes.
3. Added Support for Nice and Elero devices in Gateway connection.
    As part of expanding the system's capabilities, support for Nice and Elero protocols has been added in Gateway Connection feature, improving connectivity between hubs.
What's new:
Update
    Minor translations fixes.
Dashboard
    Added the ability for the administrator account to hide "Add Device" and "Add Scene" tiles on the dashboard in general hub settings.
FTI
    Added the ability to restore user backups saved in the Cloud during the FTI process.
    Improved Z-Wave engine selection during FTI for hubs no longer connected to the Master gateway.
Garden
    Added the ability to perform a sequence test and manually start irrigation from the Garden Panel.
Elero
    Improvements for waking up Elero devices.
Energy
    Improved tooltip readability for tariffs in the Energy Panel.
    Power measurements for hidden devices are now excluded by default.
Nice
    Improvements in handling dead devices.
    Added support for partial opening state for gates.
    Added support for battery-operated devices synchronization.
Users
    Improvements for user management - simplifications in Remote Access sharing.
Other
    Improvements in user password validation.
    Refreshed modal appearance in the interface.
    Increased character limit for variables in the hub.
    Database optimizations.
Quick Apps
    Added switch support.
    Added dropdown list support.
    Changes for control identifiers.
Scenes
    Added the ability to manually start watering sequences from a scene.
    In block scenes, added new blocks related to the energy panel: Current Production, Current Consumption, and Current Balance.
    Added automatic authorization for API of system elements in Lua.
Devices
    Organized roles for blinds in Linked Devices.
    Organized the list of roles and categories for devices.
    Added hysteresis settings for humidity controller and thermostats in Linked Devices.
Zigbee
    Added support for smoke, pressure, gas, volatile organic compounds, vibration, and presence sensors.
    Added support for device role settings.
    Added support for device's temperature sensors.
Z-Wave
    Added support for Qubino Flush Shutter DC devices.
    Changed the default wake-up interval value for known old-generation devices.
    Updated support for Aeon Multisensor 6.
    Added pin support for Danalock V3 lock.
    Introduced fixes for removing damaged Z-Wave nodes.**
    Added support for old-generation FGFS-101 and FGK-101.
Bug Fixes:
Climate
    Resolved an issue with thermostat handling from the climate panel for Fahrenheit units.
Gateway Connection
    Fixed the inability to configure Lifeline association for devices from Slave hub in some cases.
Backups
    Fixed behavior for local backup limit.
    Fixed occasional backup execution issues.
Nice
    Fixes for handling parameters for BiDi-Multisensor.
    Resolved issues with Nice ON4E remotes.
    Partial opening button missing for Nice gates.
    Missing waiting icon for pending actions when changing parameters for sleeping devices.
    Improved handling of low battery notifications for BiDi-Multisensor.
    Fixed Nice device handling after backup restoration.
    Fixes for device parameter configuration mechanism.
Users
    Fixed granting permissions for empty rooms.
    Stylistic fixes for dark theme in access management.
Plugins
    Incorrect reporting of Tedee lock status during temporary loss of cloud services.
    Fixed handling of latch retraction for Tedee lock.
    Fixed generating a new authorization code for Tedee lock.
    Minor fixes in Dahua camera plugin configuration.
    Fixes for CoolAutomation plugin.
Other
    Occasional issue with web interface content not loading.
    Overwriting room categories to "Other" during editing in the modal.
    Minor UX fixes for Devices and Network tabs.
Quick Apps
    Fixed assigning QuickApps to rooms when adding a new integration from the Dashboard.
    Fixed Fahrenheit handling for thermostat-type QuickApps.
    Fixed handling of special characters for secret-type variables.
Scenes
    Filled out missing translations for thermostat actions in block scenes.
    Fixed renaming scenes from the editor.
    Fixed action handling for thermostats (temporary schedule override).
Devices
    Fixed color controller handling in Linked Devices.
    Fixes for Linked Device support for blinds.
    Fixed linked devices entities list after opening the "General" tab in devices settings.
Zigbee
    Fixes for forcing device removal.
    Improved ZigBee device counter in the configuration tab.
Z-Wave
    Fixed temperature conversion for the first Fahrenheit reading.
    Fixed estimated next device wakeup time display.
    Improved communication performance.
    Added support for new versions of MCO devices - MH-S412, MH-DT411.
    Eliminated issues with zeroing wakeup time for FGD-002.
* - Does not apply to HC3L (Home Center 3 Lite).
** - Applies only to Z-Wave 3.0 engine.
