I would like to ask, where we can found any documentation regarding to new controls available in QuickApps: switch and dropdown list.
BTW: In the newest update I can cee only dropdown list - can;t find switch.
Is it opportunity to provide any turtorial how we can use this controls from Lua level?
Fibaro - the last update on page which you recomend (
) is valid for firmware 5.021
Add new button and select Switch from new drop down list :)
    Thank you but I supposed totally different control component
    /monthly_2023_10/image.png.611de13a3a74e91eefcad22dd8d6e437.png" />
    this provided looks unusable, and no documented 😬
    Edited by Tomasz Spaleniak
    • 1 month later...
    Does anyone know how to read selected value from drop down menu?
    latest Fibaro developer documentation can be found here:
    Try this:
    Set the function as the onToggle handler:
    /monthly_2023_12/image.png.1e7ca573ea57885930071b962a09885a.png" />
    • Thanks 2
    Thank you @Joep. It worked :D
    • 3 weeks later...
    I wrote some documentation around the new Quick App GUI elements you can
    • Like 5
