DropDown List is a great new functionality, but it would be great to add this option to QuickApp variables as well. Now only text and secret variable types can be used.
But if I need to set the IP address of a device for example, DropDown List can be loaded with values from the ARP and then only select from existing device IP addresses.
Now the user has to get the IP address in a different way and then fill it in as text.
This setting is not useful to place on the main QA panel.
Thank you
/monthly_2023_10/image.png.c11f279b5218d53c62bee133a3b87b1a.png" />
Yeah, thats a long awaited featue. Enumerated variables in quickapps, the same way as it is incase of global variables.
Also, finally they should fix that incredible data type problem, when in case of sliders, or dropdowns setting variable requires the value to be a string.
Edited by Neo Andersson
