Was trying to change the parameters on an AEON Lab Energy meter that wouldn’t save, so tried a Soft Reconfigure. The soft reconfigure failed and left the device un-configured.
Then power cycling the device but the soft reconfigure stilled failed, so rebooted the hub.
After the hub rebooted about 1/3 (system has 101 devices) of the devices where un-configured.
Required a backup restore to fix the problem.
I also have problems with this version, tried to add a 'Qubino Smart Meter'. Have to manually add 'Associations' to get HC3 to update values, values don't come where they should etc.
