I am trying to integrate a temperature controller into a system using Home Center Lite. My temperature controller consists of 3 elements as shown in the picture:
1 - thermostat -> here i can enter the desired temperature either in the fibaro application or directly on the wall mounted device
2 - temperature sensor (it is located inside the wall mounted thermostat)
3 - relay -> used to turn on or off the floor heating valve
What i would like to do is to create a scene that looks like: If T2<T1, then 3 is ON
Unfortunately, the application does let me make this scene as seen in the picture.
If i try using "Linked Devices", here i can only link device 2 and device 3 and can control the temperature only via the heating panel. Goal is to control device 3 using device 1
Any hints?
Thank you!
