I added a Window-Sensor (AEON Labs Door Window Sensor Gen5, but issues occur also for other sensors) to the system which was sucessful. With new batteries the power shows 100%. After I have changed the type from "Opening Sensor" to "Window Opening Sensor" and pressed "Save", the type changes as expected but the Power is shown as 0%.
Is this a known issue?
I have the same battery notification problem on original Fibaro door window sensor.
I have a similar problem with two door opening sensors from Zipato.
