json POST syntax
Im trying to control a Danalock through a Danabridge and so far i can get the token and use it to retrieve my locks and its status but when trying to perform lock/unlock i get a 404 error.
I have translated a python implementation but this last part is not working.
The encoded json from python looks like this:
payload = json.dumps({"device": serial, "operation": "afi.lock.operate", "arguments": [command]})
The command here is either "lock" or "unlock" but since its inside brackets im not sure how to translate it.
"arguments": ["lock"] and "arguments": "[lock]" doesnt work.
Does anyone have an idea how the syntax should be?
My POST in lua looks like this:
http:request('https://bridge.danalockservices.com/bridge/v1/execute',{
    options = {
      method = 'POST',
      headers = {
        ['Accept'] = 'application/json',
        ['Content-Type'] = 'application/json',
        ['Authorization'] = 'Bearer ' ..token
        data = json.encode({
        ["device"] = lockserial,
        ["operation"] = "afi.lock.operate",
        ["arguments"] = '["lock"]'
BR
Try arguments as LUA array
["arguments"] = {"lock"}
    Thanks ivx, but it seems i still get a 404..
    BR
    HTTP error 404 means URL(https://bridge.danalockservices.com/bridge/v1/execute) does not exist and seems not related to arguments values.
    Edited by ivx
    Just try to get locks list, can you see lock in list and serial is as you set.
     url = "https://api.danalock.com/locks/v1"
     r = requests.get(url, headers={'Authorization': 'Bearer ' + token, 'Accept': 'application/json', 'content-type': 'application/json'})
    Yes, i can get both lock list and also its status (using
    But as soon as i try to lock it i get the 404 (And sometimes i have seen 500 also)
    BR
    Try to get state pf lock
    execute_url = "https://bridge.danalockservices.com/bridge/v1/execute"
        payload = json.dumps({"device": serial, "operation": "afi.lock.get-state"})
        r = requests.post(execute_url, headers={'Authorization': 'Bearer ' + token, 'Accept': 'application/json', 'content-type': 'application/json'}, data=payload)
    If it's arguments problem - .get-state doesn't have array arguments, so does this work ?
    Yes, "afi.lock.get-state" works
    use print() out json.encode() and post here.
    {"operation":"afi.lock.operate","arguments":["lock"],"device":"XX:XX:XX:XX:XX:XX"}
    Seems ok, but does remote server check arguments order - which is not same.
    Try pass raw string(without json.encode)
    '{"device":"XX:XX:XX:XX:XX:XX","operation":"afi.lock.operate","arguments":["lock"]}'
    Edited by ivx
    Now i got a 500 instead.. (internal error)
    After some re-tests, i still get 404
    Now syntax is right, can't suggest more. Only you can try
     , with this you can see raw 404 response, sometimes i have got more info from there.
    You can get token and print it out from current code. Just make
     post.
    Ok, many thanks for your help!
    Ill try your suggestion to see if i can figure out what is wrong.
    BR
    Weird, when using the API tester then it works..
    Copy paste reqbin json, but between single quotes ' ', try post raw string again.
    If doesn't work, then there must be some headers difference.
    or you need to encode the json payload if it has special chars in it.
    Yep. reqbin raw shows you exactly what data it sends to remote server ...
    One difference is that it doesn't send Accepts header.
    Edited by ivx
    Sorry, what do you mean by reqbin?
    I meant reqbin.com REST API tester.
    Also how you get token and call
    Fibaro HTTP calls are asynchronous and execute in background.
    Without seeing code, are code free of racing condition ?
    Make call to get token
       - starts executing
    Now you make call to control lock, but get-token http request still executing(no token yet)
    Edited by ivx
    Or Postman (
    ), also a fine tool to test API connections.
