Jamie 1
Anyone tried to wire one of these into the Inputs of the RGBW module so that you have full control without the app?
I have read the manual and it talks about using two switches etc and also pententinometer wiring. The unit has 4 x 0 - 10v inputs, assume this the dimmer switch will just adjust the outputs and the Fibaro can interpret this?
thanks
4 answers to this question
