Issue with updating to newest Beta
Guest theoverriet
My Fibaro wouldn't update to the newest beta. Luckily I saw the post:
I followed the steps. Went into recovery. Clicked repair..... And now my HC3 restarted with a very very old backup restored and I have to figure out what has changed since. Thanks al lot. for the 'solution'. next time maybe double check the steps./
@theoverriet Your system probably restored to the other system, secondary backup. There are two partitions.
Edited by SmartHomeEddy
Always make a back up by yourselve before updating.
As mentioned  by@Eddy perhaps you have system A instead of system B
When start recovery you can select A or B
Succes
@theoverriet as mentioned above, not sure why but probably you updated the old version of the system or switched it by mistake to old version.
Just go to recovery mode again, click "Switch" system. Let it boot up - you will be back on 5.141 beta version with your current configuration.
Follow the steps again by going to the recovery using shortcut in the web interface, use the middle option (repair) and everything will be ok.
If you will have a problem with this just contact support and they will help you resolve the issue.
This isn't working for me, i click repair and it continuously just reboots/repairs to System B.
*Edit
Ok, so you need to click auto repair, or switch to system B. Once it has switched to System B you can then select repair system A which is middle bottom.
Edited by Produno
